Home › Forum › Porsche Talk › 991 facelift
- Dit onderwerp bevat 92 reacties, 19 deelnemers, en is laatst geüpdatet op 8 jaren, 9 maanden geleden door
deepee.
Vanaf 169 gr :respekt: :respect2: :up: :first:
Is rappekes mijn VAA herberekenen se
Blijkbaar met optionele sportuitlaat!
Foto van de rode 991 is ook een “S” en deze heeft een ander type uitlaat.2 weken geleden was ik in Weissach. De facelift Boxster ,911 cabrio mogen bewonderen .Daarna een tijd achter de facelift 991 turbo 3.0 l gereden !Hij klinkt zoals een Porsche moet klinken . :up:
The new 991 (officially an update on the existing model) features a new face, a new rear end, and a new heart. That new heart is the big deal here, as the new 991 Carrera and Carrera S will be swapping out their naturally aspirated engines for an all-new 3.0 liter turbocharged flat six. The highlights are many, but chief among them are increases in horsepower and torque, as well as improvements in fuel economy. Break out your tophat and tails, it’s time to celebrate!
[b]
Engines[/b]
Let’s talk about that new 3.0 Turbo engine, because it’s pretty spectacular. The new twin-turbocharged engine offers an increase of 20 horsepower compared to previous models. The 911 Carrera now develops 370 horsepower and 331 lb/ft of torque versus the old 3.4 liter engine’s output of 350 hp and 287 tq. The new 911 Carrera S now makes 420 horsepower and 368 lb/ft of torque, whereas the outgoing 3.8 liter engine only managed 400 hp and 325 tq.It’s a no-brainer that a new 991 with more power would also have better performance. The Carrera with PDK can now run to sixty in 4.0 versus the 4.2 0-60 of the naturally aspirated model, and can now reach a V-max of 183 miles per hour. The Carrera S with PDK sprints to 60 in 3.7 seconds (versus 3.9 of the prior generation) and has a massive 191 mile per hour top speed. That’s right, a 991 Carrera S is almost a 200 mile per hour car now. Isn’t that crazy? 200 used to be reserved for only the craziest of supercars.
[b]
Chassis[/b]
The new 991.2 chassis has also been tricked out with ‘trickle down’ technology from the more expensive models, including the 991 Turbo, 991 GT3, and even the 918 Spyder. As expected, these advancements increase the car’s speed, responsiveness, handling capabilities, and driver comfort. It’s all pretty trick stuff, so let’s check out what’s in store.The new Sport Chrono equipped cars will have a mode switch dial on the steering wheel that will change how the car reacts to inputs. The old modes “Normal, Sport, and Sport Plus” are included, but the new one here is “Individual”, which allows driver-tailored customization of options, including Chassis settings, auto start/stop, PDK shifting, throttle response, and the exhaust note.
Because Porsche believes so much in this new chassis, they’ve made PASM, and by extension the 10mm lower ride height, standard on the Carrera now. No real word has been said on the changes made to the PASM system, but Porsche does comment that they have increased the dynamic capability even further than before… on the new generation. To correspond with this, rear wheels have increased width to 11.5 inches.
The Carrera S has a brand new option, too. You can now order your brand new Carrera S with optional rear-axle steering. At lower speeds, the rear steer turns against the fronts to further improve the turn-in behavior of the 911, and at higher speeds, the system turns with the fronts to aid in driving precision for long sweeping curves or changing lanes. In addition, Porsche is now offering optional electro-hydraulic lift for the front axle to aid in clearing speed bumps or driveway entrances.
[b]
Porsche Communication Management[/b]
A brand-new standard feature on the 991.2 Carrera and Carrera S is the PCM module, which now includes online navigation ability. One of our very few gripes about the 991 and 981 interiors have been the PCM and its lack of user friendliness. We really hope that this new version will fix many of those issues. Based on the information we’ve received, it looks like that may be the case.Visual Changes
For the most part, the 991.2 apes the 991.1 closely. There are new standard 5-spoke wheels. There is a new front fascia, and a new rear engine lid. The new wheels have not been shown off in these press photos, so we’ll have to wait to see exactly what they look like, but there are plenty of front and rear shots to look at.The front bumper features much larger air inlets to feed what are likely much larger radiators. Turbocharged engines create a lot of heat, and it is imperative that the radiators be able to handle that extra stress.
From the rear, your eye first focuses on the vertically straked engine cover. This visual is interesting, as the wide opening looks somewhat like that of a long-hood 911’s rear decklid, though with vertical pieces instead of horizontal grilles. With that said, the move is quite striking, and appears to be well executed. I look forward to seeing it in person. The opening is likely to facilitate a large top-mount intercooler to feed the turbos cool air. The second thing I notice from the rear is the twin tail pipes. Instead of the four-tip exit of the existing 991 Carrera S, we see a true-dual exit oblong pipe on either side of the bumper.
bron: flat6.com
enkele windstoten onthullen de gefacelifte 991 een beetje sneller dan verwacht aan het porsche museum in zuffenhausen
Op Autobild spreken ze dan weer van een 2.7 voor de ‘instapper’
Anstelle von 3,4- und 3,8-Liter-Boxern soll das künftige 911er-Triebwerk nur noch 2,7 und 3,0 Liter Volumen haben. Der 2.7er soll 360 PS leisten, beim 911 S mit dem 3,0-Liter-Boxer liegen etwa 430 PS an.
… turbocharged 3.0-liter six-cylinder engine that develops 370 PS (272 kW) in the base model and 420 PS (309 kW) in the S variant.
Een 3.0 is wel interessant. Ik ben echt benieuwd naar de prijzen van de facelift versies. Als dan de uitstoot nog meevalt zal het wel een verkoopsucces worden (in België alleszins).… turbocharged 3.0-liter six-cylinder engine that develops 370 PS (272 kW) in the base model and 420 PS (309 kW) in the S variant.
Een 3.0 is wel interessant. Ik ben echt benieuwd naar de prijzen van de facelift versies. Als dan de uitstoot nog meevalt zal het wel een verkoopsucces worden (in België alleszins).The facelifted Targa variant has a new front bumper and modestly revised headlights. The styling changes are less noticeable out back but include new air vents and modified taillights.
Despite the deja vu design, the 911 is expected to feature a new turbocharged 3.0-liter six-cylinder engine that develops 370 PS (272 kW) in the base model and 420 PS (309 kW) in the S variant.The facelifted Targa variant has a new front bumper and modestly revised headlights. The styling changes are less noticeable out back but include new air vents and modified taillights.
Despite the deja vu design, the 911 is expected to feature a new turbocharged 3.0-liter six-cylinder engine that develops 370 PS (272 kW) in the base model and 420 PS (309 kW) in the S variant.Het stuurtje oogt mooier vind ik, maar ligt minder lekker in de hand om een of andere reden. Kan het niet zo direct benoemen. Misschien is het ietsje gladder, maar ook de uitsparingen voor de duimen zijn licht anders van vorm.
Vierwielsturing op de carrera, interesting !
