lichten 3.2 USA
Home Forum Porscheforum Technisch Luchtgekoelde Porsches 911 lichten 3.2 USA
  • met mijn 3.2 uit de USA heb in waarschijnlijk een probleemke
    als ik mijn dimlichten aan leg gaan mijn mistlampen en mijn trek schakelaar van mijn verlichting geeft 3 standen.
    voor wat dient dat allemaal en is dat normaal van mijn mistlampen dat die branden ook al licht de mistschakelaar niet aan.
    • The USA cars are wired so that the fogs shut off when high beams are activated. Even this is “wrong”…as the fogs should come on independently of any hi/low beam lamps. When you truly need fogs, you don’t even want low beams “on”. The USA cars come wired so the fogs can come on only when the “low beams” are on.
      So….in the same vein as Andra’s post…move one grey trigger wire on the fuse block to allow power to the fogs whenever the parking lights are on. I’ve done this a long time ago. Now they come on whenever I want to…and if I want to…they stay on with either low or high beams too…but then I’d the same kind of A$$ as the local SUV drivers by having all forward-facing wattage “on” all the time !!!! At least you have more choices. I think the ROW ( “Rest-of-World”) cars are wired this way from the factory ( fogs acan come on by themselves), and if you have the factory repair manuals….you can see where the trigger wire needs to be.
      gevonden op: http://forums.pelicanparts.com/porsche-911-technical-forum/203497-how-fog-lights-supposed-work-carrera-3-2-a.html
