- Dit onderwerp bevat 2 reacties, 1 deelnemer, en is laatst geüpdatet op 9 jaren, 5 maanden geleden door .
22 juni 2015 om 14:20
In perfecte staat, 500km op de wagen gezeten.
Vraagprijs 100€ (Nieuwprijs 200€)Bypass pipe long 964/965 (Replace the end muffler)
170 111 045 L– + 12 crank hp & + 8 crank torque
– This “Long” secondary muffler bypass pipe is made to be used with the 964 Cup Pipe (FVD Part # 170 111 044. Its length increases backpressure so that your low and mid-range torque is not affected.
– 2 ¾” (68.5 mm) diameter tubing (reduces thermal stress)
– Weighs 4.4 lbs. (2.0 Kg)
– Replaces OEM secondary muffler.
– T 304 stainless steel
– 40% increase in sound (decibels) with a lower deeper tone.
– ECU programming is NOT necessary
– Reuses factory tips or any aftermarket tip designed to fit OEM exhaust.
– Made in Europe.
